Quick Speedometer Cable Question
Old Jul 26, 2013 | 09:13 AM
Nighthawk's Avatar
Just bought a "universal" fit speedometer cable that won't fit my 77 cutlass. It fits down on the transmission side but at the cruise control box it has the wrong fitting on the end. I've attached a picture. The upper end should have a screw-on fitting but doesn't. Any idea how to solve this problem? Should I buy another cable (and where?) or can the end be swapped off?
Old Jul 26, 2013 | 09:40 AM
olds1968's Avatar
member
i believe you need another cable as that is the wrong one. I just bought a speedo cable from rockauto.com and it works like it should.
Old Jul 26, 2013 | 10:01 AM
Nighthawk's Avatar
Any ideas where I could buy one? I did check Rock Auto but they only appear to have the upper cable which I think means it runs from the cruise control to the gauge. I need the lower cable.
Old Jul 26, 2013 | 10:06 AM
Finn5033's Avatar
I got mine through NAPA and it was correct and worked fine
Old Jul 27, 2013 | 09:49 AM
Nighthawk's Avatar
Okay, heres something else I was thinking about. Since I'm not going to use the cruise control and I don't even know if it works would it be a dumb idea to just remove it altogether. It would make the engine compartment look a little less cluttered
The Flash
Ninety-Eight
Jun 12, 2015 08:52 AM
olds67
Apr 27, 2014 09:02 AM
wolfman98
Nov 18, 2009 05:06 AM
Pfiffle
Drivetrain/Differentials
Mar 13, 2008 11:22 AM
ct1979
Dec 21, 2006 03:08 PM
