Pump Seal/Converter Leak
Old Nov 3, 2020 | 03:21 PM
tgilligan's Avatar
Sorry if this isn't an intelligent question but I want to make sure. My TH350 has a front pump seal/converter leak. I originally budgeted to have the converter replaced but other things have come up and it now has to wait. Assuming I leave it a couple of months, does that do any damage to it with the leak? Assuming I drive it once or twice until the repair gets done, is that okay as well?
Old Nov 3, 2020 | 03:42 PM
Just make sure the fluid is filled (don't let it get too low) and it will likely be OK.
Old Nov 3, 2020 | 03:52 PM
Sugar Bear's Avatar
Fun71 is correct AND your question is intelligent. There is no need to apologize, feel free to ask any questions.
When the converter is replaced the front pump bushing and naturally the seal should be done. Have you chosen a converter stall speed? If you don't specify one you'll get whatever they have. Other forum members can advise you about the stall speed if you wish.
Good luck!!!
Old Nov 3, 2020 | 06:20 PM
Other than the mess, as long as you don’t run the trans low on fluid the leak won’t hurt anything. I would think a transmission shop wouldn’t charge much to replace the bushing if you took the trans to the shop.
redbaron442455
20
Apr 22, 2020 01:13 PM
SkylinesSuck
16
Mar 23, 2015 07:34 AM
Wilson05
Sep 13, 2009 10:23 AM
cts-v
Jun 9, 2009 05:39 AM
68ragtop
Dec 1, 2008 06:00 AM
