New clutch for a 68 442 - opinions
Old Mar 31, 2020 | 06:31 AM
bigrbandit's Avatar
72 Cutlass Ponca City OK
My dad has a 68 442 with 4 speed, and what feel like 3.42 gears based on the tach. His clutch is shot after 100K miles of use. He doesn't really do internet, so I need to gather parts for him. I imagine any decent auto repair shop can R&R a clutch on a rear drive GM car. I know the Z bar bushings are also shot - it feels "sloppy". He's an older guy, and the engine is still stock, so I want something that he can both push the pedal, but wont burn to a crisp when he does a burnout. I was looking at the following, but wonder about the "high load cover". Price is only $107:
https://www.rockauto.com/en/moreinfo...=3232&jsn=3232
And these for the z bar bushings. Anything else I need?
http://www.fusickautomotiveproducts....?number=CSB349
Old Mar 31, 2020 | 09:37 AM
My442's Avatar
Centerforce I or II.
Soft pedal pressure and a great grip.
Old Mar 31, 2020 | 09:43 AM
Centerforce II, specifically. You won't be sorry.
Old Mar 31, 2020 | 09:50 AM
bigrbandit's Avatar
So this one then?
https://www.summitracing.com/parts/c...bile/model/442
Old Mar 31, 2020 | 11:18 AM
allyolds68's Avatar
For under 400 HP a Centerforce I is more than adequate. I called Centerforce directly and that's what they recommended for my stock rebuilt 455
Old Mar 31, 2020 | 12:08 PM
70Rocket's Avatar
If pedal effort is really an issue, you might consider a McLeod RST / RXT dual disc clutch. The pedal effort is a lot lower than the Centerforce units mentioned above. I had a Centerforce and now have an RXT. McLeod does not list a kit for our cars, so you will need to work with someone like Jody Haag to get a kit put together.
Jody Haag
Jody's Transmissions LLC
610-413-8015 EST
The downside to the RST / RXT setup is that they are expensive. You might also notice a little bit of clutch rattle if you lug the motor below about 1800 rpm.
My2nd 69 442
27
Jun 14, 2020 10:08 AM
Globeguy
Apr 29, 2017 10:25 AM
Napoleon1991
Mar 20, 2017 06:50 PM
z11375ss
25
May 12, 2013 07:09 PM
dan1s
May 15, 2008 07:42 AM
