Need Flywheel Help
Need Flywheel Help
Working on t5 manual conversion. Purchased a 10.5 clutch and pressure plate. Shop sold me a light weight flywheel along with it but the bolt pattern is not correct. It looks like a flywheel with the same bolt pattern as a chevy 350 flywheel. Maybe he grabbed the wrong one.
Does anyone have a part number or any size measurements that might help me locate the correct flywheel quickly as we have everything torn down in local shop. Thanks
So is it the bolt holes through the flywheel into the crank shaft that are wrong? I've only had factory ones that don't have a part number cast into them.
Here's a thread that cites a flywheel number
https://classicoldsmobile.com/forums...g-numbers.html
If this doesn't cross reference to the aftermarket one you want it might be worth checking ebay. I know there's aftermarket flywheels posted there.
John
John
Probably assumed it's a Chevy 350 engine because, hey, it's a GM part, right?
A quick search on Summit:
http://www.summitracing.com/search/d...-size/7-5l-455
If you're searching around, watch out for late model (cheap) flywheels. They won't work either.
Olds flywheels have 166 ring gear teeth. Chevy have 153 or 168.
http://www.mcleodracing.com/products...+Flywheels.mcl
And of course, 64-67 Olds flywheels have a different crank flange bolt pattern than the 68-90 flywheels.
http://americanpowertrain.com/c-3144...teel-166t.html
A Chevy flywheel will not fit an Olds. When you first said that your parts didnt' fit,I thought you meant that the clutch didn't bolt up to the flywheel.Now it sounds like the flywheel doesn't fit the crank,which means it is for a Chevy or some other make.
I have a Mcleod billet flywheel,but there are other companies maiking OEM style flywheels,aluminum,and billet,for Oldsmobile.
