my 1969 odls f-85
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
hello everyone ,need some advice on my 1969 olds f-85 2 speed trans ,every morning i have to warm up the car for 5-10 mins. then drive 1-3 miles before it shifts into 2nd gear after this it fine until the next day or it cools down i tighten the band screw but did not help .
Any suggestions??
Any suggestions??
Which 2-speed trans? Didn't Olds replace the Jetaway w/ the TH350 in '69? Is this the original trans in the car?
In any case, assuming its the Jetaway, and that the fluid level is OK and clean, check for vacuum leaks to the modulator, or if the modulator has a vacuum leak.
Would it be possible that the modulator is connected to the wrong vacuum source? Vacuum switched by a temp sensor of sorts? Agree that the fluid and filter should be eliminated first.
dabull55
September 1st, 2013 08:22 AM
dgp_naples
17
January 29th, 2013 02:13 PM
