Muncie speedo gears
Old Jan 28, 2016 | 06:13 AM
edzolz's Avatar
Muncie speedo gears
In my 67 Chassis manual, there is a section that shows different speedometer gearsets for the different ratio rear ends. Some of the drive gears (the one on the output shaft) in some sets have 17 teeth. I have never seen this drive gear in any Muncie and I have been into lots of them. Is this a special trans or just a hard to find gear?
Old Jan 28, 2016 | 11:46 AM
Now you have. It's the purple one. $11 from this vendor.
Old Jan 28, 2016 | 12:28 PM
69Cutlss's Avatar
I agree, the Drive gear is typically 8 or 9 in a Muncie and steel. The driven gear can be a wide range depending on differential. I'm running an 8 drive and 22 driven. Perhaps someone installed a different set somewhere down the line?
Old Jan 28, 2016 | 04:23 PM
crash's Avatar
Muncie never used a 9 tooth speedo drive gear on the main shaft...
Muncie used 6-7-8 tooth drive gears of different diameters...
ST-10's used 7-8-9 tooth drive gears all the same diameter...
Hope this helps... Crash
Old Jan 28, 2016 | 05:36 PM
69Cutlss's Avatar
LOL. So quick to contradict. I trust you feel strong? I never said Muncie used anything, I said the drive gear is "typically..." Besides, instead of responding to a respondent, address the original question that you never addressed.
Old Jan 29, 2016 | 06:12 AM
edzolz's Avatar
None of these replies address my original post. I will try to scan the page I'm referring to from my 67 chassis manual.
Old Jan 30, 2016 | 06:09 AM
edzolz's Avatar
My mistake, the larger drive gear is in the automatic transmissions, not the standard shift.
66-3X2 442
Jul 18, 2015 05:55 PM
Magna86
May 17, 2015 02:24 PM
Steve g
Drivetrain/Differentials
Aug 3, 2013 08:12 PM
Steve g
Aug 3, 2013 08:10 PM
Flye
Mar 11, 2011 08:06 PM
