muncie-90 degree speedo gear drive
Old Jun 20, 2021 | 08:02 AM
ben442's Avatar
Am I missing an end cap here?
Have had intermittent speedometer issues lately and just having a look now.
Old Jun 20, 2021 | 08:11 AM
JIM'S w30's Avatar
End cap is gone get a hole saw cut a piece of tin glue on with Right Stuff silicone
Old Jun 20, 2021 | 08:12 AM
ben442's Avatar
sounds like a plan, thanks Jim
Old Jun 20, 2021 | 10:26 AM
ben442's Avatar
Speedo gear drive part 2
Well after making a seemingly suitable repair I found the end cap and small washer sitting right on the transmission cross member.
Does this need a O-ring in the grove?
Thanks.
Old Jun 21, 2021 | 04:26 AM
rob1960's Avatar
Boy you sure lucked out finding the parts on the crossmember!! No o-ring that I'm aware of. I'd clean it up real good & put a little adhesive silicone around it. You might want to use a small center punch & go around the opening to tighten it up a bit before you press that end cap back in.
Via3d
Sep 23, 2018 10:42 PM
ddunmore81
Jul 1, 2017 09:24 AM
ostie13
May 14, 2016 08:05 AM
88hurstolds
Aug 5, 2015 09:00 AM
Redbud40
Jul 1, 2014 05:28 AM
