Mounting an transmission cooler
Old Jun 6, 2009 | 05:06 PM
The Stickman's Avatar
I am trying to figure out the best way to locate some things. I have a new radiator and have an PermaCool oil cooler with fan. Now fitting the cooler in front of the radiator looks to be a mess as the way things are in there. So I was wondering can I mount the cooler on the backside(engine side) or would this make the cooler ineffective? Also can I mount it so the lines come in from the bottom rather than the side?
Old Jun 6, 2009 | 06:34 PM
Top, bottom, side - the orientation of the cooler lines doesn't really matter. The fluid is pressurized and any trapped air will be pushed through. You do want to mount it in front, however. Are you talking about the Custom Cruiser? Mine has tons of room. I mounted the factory trans cooler from a D-body Fleetwood.
Old Jun 6, 2009 | 09:17 PM
Yea on the Custom Cruiser. There are those cross bars right in front of the A/C condenser and the cooler I have had flanges on it to bolt it down with rather than using push pins or ties. So I just don't know where to bolt it to.
My442
Mar 21, 2018 06:20 AM
84oldsDelta88
Mar 30, 2011 09:16 PM
dallasite21
Sep 29, 2010 03:32 PM
#1CutlassSupreme
Jun 14, 2009 08:45 AM
The Stickman
Jun 12, 2009 03:34 AM
