M22 rebuilt and leaking in front
Old Jun 3, 2015 | 12:23 PM
Pokefase's Avatar
I just had my 4 speed Muncie transmission rebuilt in my matching numbers 442. It is leaking in the front and the mechanic says that when they made these trannies they didn't have a gasket. It's literally metal against metal. Does anyone have a remedy for the leak?
Old Jun 3, 2015 | 01:40 PM
47 Convertible's Avatar
I googled Muncie M22 exploded view.
Take a look at this exploded view of Muncie with accompanying parts list: http://myss396.com/ChevelleInfo/Tran..._Exploded.html
That sure looks like a gasket at the front but maybe a different model of Muncie?
Jerry
67442nut's Avatar
Are you sure about where the leak is exactly?
I've had problems in the past with the hole in the front of the main case where the cluster gear shaft mounts.
Apparently the cluster gear shaft wears the hole over time causing it to leak.
The only fix is to replace the case.
Hopefully, this is not your problem, but, wouldn't hurt to give it a look.
Old Jun 3, 2015 | 02:01 PM
Items #7 and 8 in the above exploded view keep the oil from coming out the front bearing retainer.
Old Jun 3, 2015 | 02:08 PM
RandyS's Avatar
Part #2 is the gasket between the bearing retainer and the case. That is where your leak is coming from. You need to get a new mechanic...........
Old Jun 3, 2015 | 03:24 PM
Magna86's Avatar
If the cluster gear pin hole is worn and not a tight fit it will drip. You don't have to replace the case. They can bore the hole and press in a bushing to restore the original figment. Atleast manual transmission shops can do it. Not sure about a regular mechanic. It should not leak after being rebuilt
Old Jun 3, 2015 | 03:38 PM
oldsmobiledave's Avatar
more info needed
Good luck with your leak. Since you state that this M-22 is original to your car you have now told us that you own a 1971 442 4 speed car (since the M-22 was only available in an Olds that year. How about telling us about you & your car?
Old Jun 3, 2015 | 06:33 PM
Pokefase's Avatar
Your right!
I made the mistake and took my 1967 convertible 442 to All Transmission World in Orlando, Florida and these guys are a bunch of muppets! Since it is still under warranty they will get it right! Thanks for all the posts! Very helpful. Looking for new mechanic as I type.
Old Jun 3, 2015 | 06:41 PM
Pokefase's Avatar
I have a 1967 Olds 442 4 speed with matching numbers. I took it to get the tranny rebuilt and the guy tells me I have a Muncie M21/M22. I'm thinking how can that be? It is either one or the other. I wasnt't able to go into bay to visually inspect case and numbers. So I am going by the mechanic from All Transmission World ( wearing the pop bottle glasses). So needless to say, I'm sure it's an M21. (I'm still learning). I'm going to take (recommend) to google the exploded view of the tranny to the Quasi professionals and maybe they can find a solution.
Old Jun 3, 2015 | 06:47 PM
Pokefase's Avatar
I will recommend that as well. I should have done my research before taking it to that shop!
Old Jun 3, 2015 | 06:48 PM
67442nut's Avatar
After thinking about it, it was 1970 when I had this problem-45 years ago.
At that time the only remedy was a new case.
I guess I should've realized that a better alternative would have been developed by now.
Old Jun 3, 2015 | 08:41 PM
more
Clearly not an M-22 or not original to your car. Again good luck fixing the leak. When you have time we would love to see pics of your 67 442.
Old Jun 4, 2015 | 05:08 AM
jozw30's Avatar
Sigh....having the same issue with my w30. The last attempt to fix made it leak worse.......
If anyone has any details about pressing in a "bushing" please add it here.
I'll definitely mention it to the guy. He's at least committed to fixing it.
Old Jun 4, 2015 | 05:25 AM
allyolds68's Avatar
main case countershaft bushing- $329
http://www.riversidegear.com/muncie-...0-3925661.html
Old Jun 4, 2015 | 05:45 AM
garys 68&72's Avatar
Muncie has no seal on the input shaft/ That's how it's vented. The input shaft nut acts a slinger and oil drains back through the passageway in the bearing retainer.
Check to make sure there's a gasket on the bearing retainer and it's oriented correctly. Also that the nut is not on backwards.
Most likely, it's the 7/8" countershaft front case hole that's wallowed out. You'll need to ship the case to a shop familiar with that fix. I searched and found a few places that did it for about $75 years ago. If not numbers matching, you can get a "supercase" for a few hundred.
Old Jun 4, 2015 | 07:31 AM
Pokefase's Avatar
Old Jun 4, 2015 | 02:57 PM
Pokefase's Avatar
Spoke to mechanic today, Apparently there wasnt a gasket for the M21 then in 1967. When he rebuilt it he negleted to find an updated gastet for the front. He has finally found a place in the Orlando area to fit a gasket on front casing. He states rear diff can somtimes pump out fluid if the mounts are loose
Old Jun 4, 2015 | 03:06 PM
Pokefase's Avatar
Originally Posted by joesw31
I would think that the mechanic installed the front bearing retainer gasket, however, he could have stripped the front bearing thread holes. Also, in 1967 they used different front bearing bolts, and if they changed the bearing retainer without changing the bolts, then, it will also leak. Find a different shop.
I'm def not going back there. Rebuilt the tranny but didn't place a gasket in front cuz they didn't make gasket for it then. He attempted to do OEM specs. Once he realized he screwed up when I brought it back, b/c it was still leaking he decided to do it right and order an after market gasket for it
Old Jun 4, 2015 | 03:07 PM
Pokefase's Avatar
I have a real nice counter case that I may sell. Let me know if there is any interest.
Much appreciated. But I think the solution is in hand. Will def keep you in mind. Thanks
Old Jun 4, 2015 | 04:50 PM
RandyS's Avatar
Spoke to mechanic today, Apparently there wasnt a gasket for the M21 then in 1967. When he rebuilt it he negleted to find an updated gastet for the front. He has finally found a place in the Orlando area to fit a gasket on front casing. He states rear diff can sometimes pump out fluid if the mounts are loose
I have to call Bull Shyte on that guy. The 67 transmissions (which has the same case as the 66) did come with a gasket on the bearing retainer, and the rebuild kits come with them. That rear diff statement is crap too, it might pump out some oil if it was overfilled........
Those gaskets are available everywhere - eBay and all the parts dealers. I would request a print out of exactly what he replaced when he rebuilt your M21. BTW, a mid priced rebuild kit is under $200.00. That includes all new bearings, synchros, seals, gaskets, etc. Nothing extra needed except to fill it back up with gear oil.
Old Jun 4, 2015 | 05:38 PM
Pokefase's Avatar
I totally agree with you on that! Such a rag tag garage! Lesson learned. I think that place wasn't experienced with such classic cars as mine. But I'm at their mercy until they fix it right (for free)
Old Jun 4, 2015 | 05:40 PM
Pokefase's Avatar
Can't download pics b/c security token? WTF? Gotta wait for moderator/administrator.
Old Jun 4, 2015 | 06:00 PM
RetroRanger's Avatar
72 Olds CS
pics are to large you need to resize them w a program (like irfan view free for download )
or host them externally on a site like photobucket and link to them
there is a sticky w a picture tutorial to help
Old Jun 6, 2015 | 05:31 AM
Are you saying he told you there's no gasket for an input bearing retainer on a 67?
Total BS............... I just rebuilt a 66, they all use a gasket.
And what the hell does this even mean? "He states rear diff can sometimes pump out fluid if the mounts are loose"
Go somewhere else.
Arrowstorm
Aug 14, 2014 04:07 PM
fast67vellen2o
Jun 29, 2014 12:28 PM
fast67vellen2o
Oct 4, 2010 11:02 AM
olds4life
Jun 11, 2009 05:33 PM
woodie582
Jul 25, 2008 06:48 PM
