Lost park... then lost reverse
Old Feb 1, 2014 | 04:16 PM
runnin350's Avatar
Ok so the other day I backed the Olds into the garage and could not put it into park (TH400)- its like it wouldn't shift into that last spot. Then today I went out to work on it and now I have no reverse! The top spot in the sequence is netral and then drive down from there. I pulled the header and pipe to access the linkage and nothing seems looks or looks like it has moved lately, is this something I can fix or is this internal ya think?
Old Feb 1, 2014 | 05:06 PM
nsnarsk65cutlass's Avatar
Column or floor shifter?If floor check the cable.
Old Feb 1, 2014 | 05:26 PM
runnin350's Avatar
Its on the floor- I pulled the center console to check and everything moves normally. No binding inside or underneath.
Old Feb 1, 2014 | 05:29 PM
Octania's Avatar
Sounds like the adjustermenter on the equalizer [frame to trans link] is loose and out of whack, if column shifted
Old Feb 2, 2014 | 06:37 AM
runnin350's Avatar
I think I figured it out, there is a little clip on there by the bracket- almost looks like a body shim that was spinning freely and had come loose. I pulled the cable out of the bracket and re-assembled it and it's much tighter and I can cycle through all the gears now. I'll hook the exhaust up tomorrow and see if it really does work.
Joffroi
Jul 11, 2010 06:44 AM
firefrost gold
Hurst/Olds
26
Feb 1, 2010 02:18 PM
audiodox
Feb 16, 2009 11:05 AM
pinky
Nov 5, 2007 09:20 AM
emarkay
Nov 14, 2005 09:13 PM
