Lost leaking trans thread.
Morning all.
Yesterday I saw a thread about a chap asking about a leaking transmission.
Great advice was given as to what seals and other items to replace while working on the trans.
It may even be related to an engine removal and the trans was an extra bit that the chap wanted to work on.
I should have book marked the thread at the time.
I did the search and went through as many latest threads I could and have obviously missed it.
Does anyone recall the thread.
Thanks.
Thanks.
I can't recall the thread but
there are four O-rings. The modulator,
trans filler tube, speedo housing,
kickdown cable if a 350 turbo and
shifter selector shaft seal.
Other than the front and rear seals,
a pan gasket and filter, should be leak
free and good to go.
I would also replace the accumulator cover o-ring too. It is on the passenger side of the 350.
