Long tail th400 in cutlass
Old Sep 6, 2024 | 11:33 AM
shiftbyear's Avatar
Any issues (besides driveshaft) in mounting a long tail TH400 in a 1970 Cutlass? Any crossmember, speedo issues?
Old Sep 6, 2024 | 01:36 PM
HydraMatic's Avatar
T.H. 400 Extension
Propellor Shaft Alignnment
Review pages 4A-3 onward in the 1970 Service Manual.
Short extension (group 4.317) is for Cutlass. Long extension is for Vista Cruiser. Longer extension is for Cadillac.
Old Sep 6, 2024 | 04:59 PM
4speed455's Avatar
I ran a long shaft turbo 400 from a 68 Delta in my 70 Cutlass. I put a shift kit in it, installed new chrome pan and gasket, I replaced the front and rear seals and had the driveline shortened to fit. After I had it installed I realized there was no provision for a speedometer on the transmission.
Old Sep 7, 2024 | 08:28 PM
The 1965-70 Olds full size cars drove the speedo from the left front wheel. Transmissions from those cars typically do not have any provision for driving a speedo. The case is not machined for the speedo gear adapter.
Old Sep 7, 2024 | 08:36 PM
Is the boss there if one were to retrofit?
Old Sep 7, 2024 | 08:43 PM
You would have to completely disassemble the trans and have the hole bored with enough control on tolerances so that the O-ring on the adapter seals.
bigdooly
Nov 21, 2021 07:28 AM
83hurstguy
Sep 23, 2019 08:07 PM
shiftbyear
Jan 12, 2018 07:18 AM
sammy
Nov 17, 2015 10:26 AM
DLaz70OLDS98
Mar 27, 2015 06:01 PM
