Linkage diagram..
Old Jan 25, 2025 | 08:28 AM
Tancuda's Avatar
Linkage diagram..
Hi, is this diagram the same for a 71 cutlass auto on floor ? Thanks
Old Jan 25, 2025 | 08:42 AM
I don't have time to evaluate differences (too much on my plate at the moment). I'll provide you w/ what I think might be the appropriate diagrams from my 1971 PIM.
Old Jan 25, 2025 | 11:35 AM
The column shift linkage parts are also used on floor shift cars to serve as the backdrive linkage. This locks the shifter with the key and also operates the NSS/backup light switch, which is on the column even for floor shift cars. Note that the U-shaped lever that bolts to the trans says "Except 35D55 and 35W26", which is similar. D55 is console and W26 is dual gate. Both of those used a U-shaped lever that has an extra tab for attaching the cable, as shown drawing Norm posted from the PIM.
Old Jan 25, 2025 | 06:00 PM
Tancuda's Avatar
Wow, thanks a lot Vintage Chief, what could I ask more !
Old Jan 25, 2025 | 06:14 PM
Tancuda's Avatar
Ok thanks Joe for the great explanation, and seriousy I thought that the column shift linkage was leftover from a conversion from auto on column to floor shift !
And here's a shot of my linkage near the frame bracket, looks like the spring is missing and the rubber bushing is not like in the drawing, can I have your opinion on this ?
Thanks for your time.
Old Jan 26, 2025 | 06:24 AM
That's been hosed up by a previous owner. You can buy the correct replacement parts from pretty much any of the usual repro vendors.
Old Jan 26, 2025 | 07:36 AM
Tancuda's Avatar
Great, thank you
GKranig1
May 31, 2023 12:20 PM
Charlie D
Nov 25, 2021 04:49 PM
72455
15
Sep 5, 2021 04:02 AM
67abody
Oct 18, 2015 06:19 AM
4424me
May 13, 2012 06:02 PM
