Diagram and parts source needed for shift linkage
Old Aug 28, 2021 | 05:32 AM
72455's Avatar
1972 U code Supreme
The automatic shift linkage for my '72 Supreme with a TH400 is sloppy so I think I'm missing some bushings. Can some post a good diagram of the assembly and a good source for what I need?
EDIT: So upon further inspection, the rod pictured below slides back and forth in the slot. Is that how it is supposed to be, or do I need a bushing in that slot?
Old Aug 28, 2021 | 01:35 PM
Loaded68W34's Avatar
It is supposed to be like that, there should be a spring and bushing over on the frame side of that rod where it sits in the bracket bolted to the frame.
Old Aug 28, 2021 | 01:44 PM
72455's Avatar
1972 U code Supreme
You're talking about this, correct?
Old Aug 28, 2021 | 02:02 PM
4speed455's Avatar
Look like your missing the spring. I bought the kit from in-line with the spring, bushing and hardware.
https://www.ebay.com/itm/390168542347
Old Aug 28, 2021 | 02:53 PM
72455's Avatar
1972 U code Supreme
Thanks for the link...obviously my spring is MIA, and I've been fine without it. I ordered the kit, but just out of curiosity, what is the purpose of the spring other than to keep the rod from sliding back and forth?
Old Aug 28, 2021 | 03:15 PM
4speed455's Avatar
The spring and washer keep the bushing in the cup on the bracket. Your bushing has slipped out, that’s why your feeling slop in the linkage.
Old Aug 28, 2021 | 04:43 PM
1972 FAM Automatic Transmission Shift Linkage
Old Sep 4, 2021 | 06:56 AM
72455's Avatar
1972 U code Supreme
And that's that with rhat...easy job too. Popped the hairpin clip off the rod, slid the rod out of the bracket, slid all of the hardware on and buttoned everything back up. Took me about 10 minutes 😀
Old Sep 4, 2021 | 09:54 AM
You should notice a marked improvement in reduction of slop.
Old Sep 4, 2021 | 10:04 AM
RetroRanger's Avatar
72 Olds CS
Looks good is it better?
Old Sep 4, 2021 | 12:29 PM
72455's Avatar
1972 U code Supreme
Thanks...didn't really have any issues with shifting, just the slop when I would move the rod back and forth, but it does seem to shift tighter now😀
Old Sep 4, 2021 | 12:33 PM
If you have a console shifter, it won’t make any difference in the shifting as that is accomplished with a cable, but it will take the slop out of the steering column collar, the NSS, and make the key easier to remove in Park.
Old Sep 4, 2021 | 12:47 PM
72455's Avatar
1972 U code Supreme
I've got a column shifter..wish I had a console😀
Old Sep 4, 2021 | 08:10 PM
cfair's Avatar
If you want to get really picky about shifter action, you can also look around for replacement rubber bushings & the sleeve for the column parts.
And for any other bushings your setup might have. Your local hardware store has tons of stuff that will work, or see if you can get reproduction GM stuff.
Usually these rubber parts are pretty well worn 50 year later, if you can find replacements, you’ll probably feel the difference.
Old Sep 4, 2021 | 08:35 PM
Well, in that case having the slop out of the linkage should make a noticeable difference in gear positions.
Old Sep 5, 2021 | 04:02 AM
72455's Avatar
1972 U code Supreme
Ya know, now that you mention it, I did notice that yesterday.
evertl
May 26, 2020 01:01 PM
My2nd 69 442
Nov 18, 2018 02:41 PM
young olds
May 1, 2018 04:55 PM
wyteon
Oct 2, 2017 09:03 AM
1971viking
May 14, 2012 07:57 AM
