Kickdown cable
Old Jan 27, 2018 | 03:20 PM
Coty1186's Avatar
Kickdown cable
Heys guys, just bought my first classic car a partially restored 1969 Cutlass supreme. Once I got home I noticed the cable going from the gas pedal to the transmission was broke. I've went to all 4 autoparts stores in town and nobody can get one to pull up on the computer. I've also googled it but haven't had no luck finding one that looks like the one that's on it, I'm not sure if it's already been replaced once with a different one. If anyone has a part number or a website that has one that would help alot, thanks.
Old Jan 27, 2018 | 03:41 PM
2blu442's Avatar
I may have a used one, but here's a link to a reproduction one. Does the one on your car look like this?
http://www.fusickautomotiveproducts....?number=TKC682
Old Jan 27, 2018 | 03:46 PM
That's the correct one, and at $63 it's a bargain. Supercars has it for $69, The Parts Place for $73, and OPGI sells the same cable for $103.
Old Jan 27, 2018 | 04:51 PM
Coty1186's Avatar
That's it and the cable has a small crimped end on it.
That's looks like it but looking at that one mine doesn't look broke. The little plastic cylinder on the cable slides right through the hole on the pedal and will just slide out. Maybe the cable is fine and I'm just missing something on the pedal. I have never even heard of a kickdown cable till I bought the car so I'm not sure what it's supposed to look like or how it connects I just know it won't stay in the pedal now.
Old Jan 27, 2018 | 05:21 PM
You're missing the metal clip that goes on the short rod crimped to the end of the cable. The clip is spring loaded and can be adjusted on that rod to change where the trans kickdown engages.
Old Jan 27, 2018 | 05:45 PM
Coty1186's Avatar
Thanks that helps alot, dose a new cable come with that clip, guess I'll start looking for a clip now.
Old Jan 27, 2018 | 07:50 PM
CS-Bill's Avatar
I'd call the people who carry the cable, they probably carry the clip.
Old Jan 27, 2018 | 08:31 PM
Ensure that the plastic insert for the hole in the pedal is there. I somewhat recently got my car back from the transmission shop and the insert was on the floorboard and the trans wouldn't downshift because the cable slipped through the slot on the side of the pedal.
Old Jan 27, 2018 | 08:34 PM
Can you post a pic showing the end of the cable? What I can see looks like the one on my car, with the tubular sleeve that is a spacer on the end of the cable, and on mine there is a keeper crimped onto the metal cable on the outer end of the sleeve.
Sorry for the crappy pic but that's the best I can get from my phone on a Saturday night.
Old Jan 28, 2018 | 05:29 AM
Coty1186's Avatar
Mine looks exactly like the picture you posted, my pedal is just missing that plastic insert. The cable has that same crimp on also. That picture helps alot I'll see what I can come up with. Thanks for the help.
Old Jan 28, 2018 | 08:05 AM
That doesn't look like any factory instillation I've ever seen. How do you adjust it? Every TH350 Olds I've ever worked on had the clip as in the photo I posted. This is also what is shown in the Chassis Service Manual.
Old Jan 28, 2018 | 10:51 AM
Joe, it looks almost identical to the picture you linked in post #3.
No idea how it is adjusted as I never had to perform any adjustments since I got the car last century (Ha!).
Old Jan 28, 2018 | 11:43 AM
??? Look again. The factory configuration uses a spring clip, not the crimp and tube or spacer or whatever that is. The whole point of the spring clip is that you can slide it along the fitting on the end of the cable to adjust where the kickdown occurs relative to throttle position.
Old Jan 29, 2018 | 12:00 PM
As I said, mine looks like the one you linked below:
mhood
Aug 19, 2010 02:38 PM
rocketscientist
Mar 11, 2010 04:30 PM
PmL69
Mar 3, 2009 07:59 PM
mark8918
Feb 6, 2009 09:34 AM
bigbrother
Jun 18, 2007 12:34 PM
