jetaway/TH350 swap detent bracket
Old June 2nd, 2011, 09:45 AM
billykissell's Avatar
i have been misinformed regarding the proper bracket to hook up a detent cable for a th350 with edelbrock carb. does anyone know the "correct" part to make this happen? TCI, Edelbrock, and Summit have all been wrong so far. I realize they are not looking at the car. They have all suggested a part that bolts to the outside of the intake manifold. i need one that mounts at the base of the carb. I really appreciate the expertise here.
billykissell is offline
Old June 3rd, 2011, 07:48 PM
Big Todd's Avatar
I bought mine off of ebay It's adjustable
Big Todd is offline
Old June 6th, 2011, 05:42 AM
do you know what brand? part number? the problem has been that the parts have been listed as applicable for "GM". what they should have said is "chevy".
Old June 6th, 2011, 06:54 AM
That's pretty universal in the Chevy-centric world. Unless the part specifically says Oldsmobile, it isn't.
joe_padavano is online now
Old June 6th, 2011, 07:21 AM
i am quickly learning that.
Old June 6th, 2011, 08:56 AM
The mid-70s Oldsmobiles used a kickdown bracket that bolted to the back two carb bolts on the intake. Is that what you're looking for?
Old June 6th, 2011, 09:22 AM
Is that on all models or just A-bodies? do you know if the carb setup matters? square bore vs. spread bore. i just put an edelbrock on it with the adapter plate.
Old June 6th, 2011, 01:19 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
http://www.summitracing.com/parts/TCI-376700/
J-(Chicago) is offline
Old June 6th, 2011, 01:34 PM
Actually, pretty much any Olds with a TH350 from the mid-1970s to the early 1980s. These brackets fit a Q-jet bolt pattern. You have to cut and weld to match the square bore bolt pattern.
Old June 6th, 2011, 02:06 PM
1965cutlassragtop's Avatar
i had mine made, it's not to dificult to fabricate....mine is just a "L" bracket with a hole on one side to mount to the manifold, and a hole on the other side to fasten the cable too. pretty simple, and only cost me about $8 for the material itself.
1965cutlassragtop is offline
Old June 7th, 2011, 05:17 AM
Originally Posted by J-(Chicago)
It's frustrating that niether the folks at TCI nor summit couldn't recommend that
jerseyjoe
July 12th, 2019 10:08 PM
Bitburger
July 14th, 2015 02:28 PM
Bitburger
June 30th, 2015 06:59 AM
Tony72Cutlass'S'
September 8th, 2012 12:05 PM
84oldsDelta88
September 30th, 2011 09:20 PM
Quick Reply: jetaway/TH350 swap detent bracket
