Installing a Dual Gate on a 70 442 from an automatic console shift need help!!!
Old May 27, 2020 | 02:09 PM
ethelwulf's Avatar
Ok I’m trying to round up the last parts needed to swap my 1970 442 console shift automatic to Hurst Dual Gate. I need the screws to fasten the shifter to the car, the screws to attach the neutral safety switch bracket to the shifter mounting bracket, the pin and clip to attach the neutral safety switch to the shifter and the pin and clip to attach the shifter cable to the shifter. Any help would be greatly appreciated.
Old Apr 24, 2022 | 07:16 PM
tkcutlass's Avatar
I am in the process of doing the same thing and need the same parts you shown above, including the NSS brackets.
Got a source?
Old Apr 25, 2022 | 07:09 AM
ethelwulf's Avatar
This is the guy I ended up getting my pins from hopefully he can do the same for you…..his name is Mike mjsiedl@megavision.com Good luck
Old Apr 25, 2022 | 07:45 AM
4speed455's Avatar
https://www.shifterdoc.com/productca...0060-p1747.htm
You can get the pin here. As far as the NSS, I took the easy way out when I converted to dual gate and I used the column mounted setup that column shift and 71-72 console shifters used. I think you would need a different harness though.
yeahbuddy
May 15, 2020 05:35 PM
yeahbuddy
Apr 14, 2020 01:00 PM
yeahbuddy
Mar 17, 2020 11:03 AM
RetroRanger
Feb 28, 2014 06:41 PM
Nickthefish
Oct 18, 2012 09:57 AM
