hydramatic v.s jetaway
Old Aug 12, 2008 | 09:04 AM
gerlof_1's Avatar
does the older type jetaway also fit the 394?
Old Feb 12, 2009 | 10:57 AM
d2_willys's Avatar
yes!
Old Jun 30, 2011 | 05:42 PM
Al Steinmetz's Avatar
trans conversion
I would say if you have a complete swap from a 60 I believe you can do it.Pontiac carried it through 64 as an option.Al
Old Jul 13, 2011 | 03:46 PM
rickr's Avatar
I converted a 61 Olds 4 door from a slim jim to a Jetaway back in the 1980's. It is best to have a doner car. ( I used a 59 88) The flywheel, lower engine bellhousing, drive shaft, rear engine mounts, linkage, and trans floor hump have to be changed out. Maybe even the starter motor, I canot recall on that.
Pookster6
Jan 14, 2016 02:29 AM
DreWRoolZ
Oct 3, 2011 05:39 AM
kgenesse
Apr 10, 2011 05:36 AM
The_German
Mar 5, 2011 11:09 AM
TECH9TWISTA
Jul 16, 2006 06:51 PM
