Hurst Shifter Info 68 442
Old Jun 26, 2025 | 05:50 AM
MikeManer's Avatar
I'm converting my 68 TH400 to a Muncie 4-speed. I'm using the factory shifter hump for a 68 Cutlass/442 and I want to make sure I use the correct shifter and installation kit to locate it properly. I have several used Competition Plus shifters, and I'm hoping I have one with the correct shifter arms. I also have a few installation kits and again I'm hoping I have the correct one. Would anyone be able to give me the part # for the shifter and the installation kit that I need? Thank you to anyone that can help.
Mike
Old Jun 26, 2025 | 08:51 AM
66-3X2 442's Avatar
Mike
If you want a complete correct OEM restored Hurst shifter with everything needed to install it I have it. I also have the same unit in unrestored but in great condition. It's all OEM GM parts with rods, arms mounting plate etc. The OEM linkage rods are larger and more beefier than the Hurst aftermarket parts. If interested PM me or contact me @ pchopesq@aol.com
Old Jun 27, 2025 | 07:25 AM
allyolds68's Avatar
Mike
Shifter use:
End view of a 66-69 shifter. All 66-69 shifters are a straight handle. There is no difference for console vs non-console
If you currently have a floor shift automatic these are the dimensions that you need to cut around the existing shift cable:
Picture of an existing shifter hump for reference:
Old Jun 27, 2025 | 10:43 AM
MikeManer's Avatar
Mike, I can't tell you how much I appreciate those pictures and images. That is a huge help. Thank you.
Mike
MikeManer
Feb 9, 2018 08:35 AM
dejavu442
Hurst/Olds
Sep 17, 2017 05:40 PM
JIM'S w30
Jul 23, 2010 06:29 PM
1968 42
Apr 24, 2008 02:35 PM
1968 42
Apr 3, 2008 05:15 PM
