Hurst shifter handles?
Old December 5th, 2014, 09:29 AM
Eddie Hansen's Avatar
Hello all , my 1969 Cutlass has the m-20 4 speed, when I bought the car it had the 442 competition shifter handle , but it was bolted to a standard competion plus shifter, meaning it wasnt pressed in it was bolted on...69 442
As my car is not a 442 I want to use the competion plus it will accept all the bolt on handles but which one?
I plan on using the stock console and I do not want to cut up either the floor which I repaired or the console?
Any thoughts on which number shifter stick I should use? in lieu of that anybody know the measurements of a stock 69 442 stick that used a console?
Eddie Hansen is offline
Old December 5th, 2014, 11:52 AM
GEARMAN69's Avatar
I have the original HurstCompetition Plus shifter and correct "H" marked shifter for sale that is for the 68-69 350 Cutlass and F85 cars as well as same year 442 version. $200 for each, both have the OEM shifter and push lock sticks.
GEARMAN69 is offline
Old December 5th, 2014, 12:56 PM
Thank you, yes I saw that, was it for a console car?
Old December 17th, 2014, 07:17 AM
GEARMAN69's Avatar
I understand that the 67-69 shifters are interchangable with or without console only , one shifter only unlike the 70-72
Old December 17th, 2014, 07:25 AM
allyolds68's Avatar
Eddie,
The correct shift for your car would have the "H" on the handle but not the "442". There two different handles, one for non 442 applications ("H") only and one for the 442 ("H" and "442)
The previous poster is correct. There is no offset in either of those handles. As long as you're using the correct shifter mounting plate on the tranny it will come throught the floor in line with the console shifter hole
allyolds68 is online now
Old December 17th, 2014, 10:04 AM
GEARMAN69's Avatar
$200 including shipping, I can hook u up with correct 3138 Comp/Plus shifter and H stick #3759
Old December 18th, 2014, 05:15 AM
thank you..
Thanks fellas,
Old December 19th, 2014, 03:28 AM
My442's Avatar
Here you go.
My442 is offline
Old December 19th, 2014, 05:21 AM
Thank you sir as an aside in 69 I see console no console what about bench seat? Would it be the same stick or one with a bigger curve, could you give me the measurment of the 69 stick? As I said I have a shifter its perfect, it had the 442 stick attached but it was obviously drilled to fit a new mechanism, I have a couple of hurst sticks wanted to choose the one closest to what should be there... much appreciated...
Old December 19th, 2014, 06:26 AM
allyolds68's Avatar
Eddie,
Again.....the 69 stick is straight, period. The only difference is the writing on the handle. Bench, bucket, console, non console all the same geometry. The three speed stick is the same too
Old December 19th, 2014, 07:23 AM
Thanks Mike,
got it now lol...
Reason I asked regarding the bench, I personally think there is nothing sexier than a bench seat 4 speed... love em to death.... always thought about changing mine to a bench, but then I also like the console .... decisions decisions LOL...
67442nut
September 16th, 2017 01:23 PM
marxjunk
June 12th, 2014 12:34 PM
bcg88
Body work
February 10th, 2009 09:43 PM
Big Joe P
May 23rd, 2007 01:18 AM
nutrocker
March 25th, 2007 08:44 AM
Quick Reply: Hurst shifter handles?
