Hurst His/Hers Shifter With 200-4R OD Trans
Old March 18th, 2013 | 06:45 PM
dfire25's Avatar
"Trying to fix her right"
Hey guys,
Is anyone running a 200-4R with a hurst his/hers shifter? They sell a retrofit kit for it and I'm wondering if it works. Any problems? Does it function like normal? Please let me know. Thanks
Old March 19th, 2013 | 06:18 AM
Majic Jack's Avatar
His her 3 on a 4
The his/hers is designed for a three speed tranny and the 200 4R is obviously a four speed, not likely you will succeed with that manuever.
Old March 19th, 2013 | 07:05 AM
2blu442's Avatar
Shiftworks has the setup, but Joe P. has commented that the 4th gear is where the neutral location presently is. Attached is a link to the company that sells this, then below that are several old threads discussing this swap.
John
http://shiftworks.com/cutlas70-72.htm
https://classicoldsmobile.com/forums...eed-trans.html
https://classicoldsmobile.com/forums...e-shifter.html
https://classicoldsmobile.com/forums...r4-200-4r.html
https://classicoldsmobile.com/forums...-71-442-a.html
Old March 19th, 2013 | 09:03 AM
dfire25's Avatar
Thanks John for the info and the thread links. Great information.
Old March 19th, 2013 | 12:37 PM
Hurst USED to make an aftermarket dual gate for the 700R4 and 200-4R in the early 1980s. It's long out of production. Units show up on ebay rarely and sell for stupid money when they do ($600 and up! ). As noted, I've seen the Shiftworks kit installed and I wouldn't get one. All it does is change the lever arm ratios so that you engage fourth when the lever is in the neutral position. P-R-N are all squeezed together in the remaining space.
Mike H.
Hurst/Olds
July 14th, 2013 04:18 PM
1970supremevert
December 16th, 2012 11:22 PM
1970supremevert
December 16th, 2012 06:59 AM
fast67vellen2o
June 9th, 2012 04:31 PM
tim72
April 1st, 2009 09:14 PM
