Hurst duel gate shifter question.
i was told that Mr Gasket sold Hurst to B&M and that B&M does not do the rebuild service. is this true? if so i have a problem with my duel gate shifter. the plate that the arm is riveted to is cracked. does anyone know where i could get this plate? it would be difficult to replace but can be done.
I used bolts with lock nuts to reassemble it. It worked out. Someone already had it apart and it seemed a little sloppy so I figured I would squeeze the tabs in a little to tighten it up did one side so far so good did the other snapped the little sucker right off. DOH!
Dale Von Krosigk
October 1st, 2013 01:54 PM
ah64pilot
May 29th, 2012 03:04 AM
