Hurst duel gate shifter question.
Old May 19, 2009 | 06:43 PM
jensenracing77's Avatar
i was told that Mr Gasket sold Hurst to B&M and that B&M does not do the rebuild service. is this true? if so i have a problem with my duel gate shifter. the plate that the arm is riveted to is cracked. does anyone know where i could get this plate? it would be difficult to replace but can be done.
Old May 27, 2009 | 05:58 PM
Eric Anderson's Avatar
Any chance you could weld the crack up? I had one that I had to tack one of the tabs that slide on the arch shaped piece back on and it worked out fine( dont ask why the tab was broken off)
Old May 27, 2009 | 06:23 PM
i think we could weld it but i will have to drill out the rivets to get the piece out. i don't know where to get the rivets. i guess i could just put screws back in it.
Old May 28, 2009 | 07:21 PM
I used bolts with lock nuts to reassemble it. It worked out. Someone already had it apart and it seemed a little sloppy so I figured I would squeeze the tabs in a little to tighten it up did one side so far so good did the other snapped the little sucker right off. DOH!
98 man
Nov 2, 2014 07:18 PM
jensenracing77
Nov 2, 2014 04:29 AM
Dale Von Krosigk
Oct 1, 2013 01:54 PM
69442
Hurst/Olds
Nov 27, 2010 09:02 PM
