Help Jetaway & 350 Transmission Lines.
Hello out there, I had an epiphany last evening and wanted to ask a question regarding the usage of th350 lines on my st-300 jetaway. More specifically, I wanted to know if I could use these pre-bent lines on my jetaway without any major modifications. I figured since the 350 tranny is swappable why not use those lines with my st300. any thoughts?
I moved this thread to the Transmissions forum for a little better visibility. Last time I did this swap was the early 1980s, but if I remember correctly, the stock Jetaway lines hooked right up to the TH350. There may have been a little tweaking required, but nothing major.
Route66Cutlass
July 25th, 2011 09:46 AM
