68 & ? Cutlass/442 brake & fuel lines...
Old Dec 10, 2010 | 01:25 PM
Indy_68_S's Avatar
Lines, lines, everywhere a line...
All parts include ride to lower 48 states....
'68 F85/Cutlass/442 front brake line set for disc brakes - 5 pc set - is set up for hold-off valve by MC - ILT # OCB68F3 - new/never used - OE steel - $55
'68-'72 ? 1/4" right side fuel return line 2 pc set for hardtop. ILT # ???? - maybe OCF70F11 ? Ordered a '68 'vert line and got this...Sticker says [70 Cutlass/442]. Same for all 68-72 ? Its definitely for the hardtop/2 door and not convertible. OE Steel - new/never used. $55
Click pics for big...
Old Dec 10, 2010 | 07:43 PM
Indy_68_S's Avatar
..and more...
'68 convertible front-to-rear main brake line. ILT # OCB68M2 Same as other years ? - Gently used - Was on car about a month & 10 miles. Took off when I did the tear down. Great condition - fittings not rounded/stripped/chewed up/etc. OE Steel - Can deliver straight in Indy metro area or I'll bend around a 30 gal trash can for shipping - $35 obo
Its the one laying on top of the frame/not clipped in the pic....I just laid it there for comparison/reference...
Old Dec 10, 2010 | 09:22 PM
JBrooks's Avatar
The front brakeline set will work for the 68 442 convertible?
Thanks,
Jim
Old Dec 10, 2010 | 10:08 PM
Indy_68_S's Avatar
Thanks,
Jim
Yes. If it has the original disc brakes with the hold-off valve mounted by the master cylinder.
There's 5 pieces
1 - Line from MC to dist block (for rear brakes)
2 - Line from MC to hold-off valve
3 - Line from hold-off valve to dist block
4 - Line from dist block to front right frame bracket for flex line
5 - Line from dist block to front left frame bracket for flex line
Lines 1,4, & 5 seem to be the same as the drum brake setup
Convertible, hardtop, 4 door are all the same from the firewall forward....
Old Dec 21, 2010 | 08:58 AM
Indy_68_S's Avatar
When I get to the bottom I go back to the top of the slide....!
507OLDS
Mar 29, 2014 12:08 PM
Eddie Hansen
Dec 4, 2012 05:14 PM
bobfo1
Brakes/Hydraulic Systems
Jul 1, 2012 11:37 AM
oldzy
Jan 29, 2010 06:06 PM
olds01
Aug 11, 2006 08:35 AM
