Half-moon shifter linkage
Old Aug 7, 2009 | 11:49 AM
I used the search function and found some good info on the half-moon shifter linkage available on the late 60s B/C bodies with dual exhaust.
http://www.442.com/tech/tech.html
I was wondering... do I need one of these half-moon shifter linkages for my 1971 Olds 98? I was under the car yesterday installing downpipes and noticed that my shifter linkage doesn't have a bend in it. When I take the car to an exhaust shop should they be able to run dual exhaust down the driver's side of the car under the shifter linkage without any problems? I know the steering geometry changed in 1971 on the B/C body. I'm just not sure if this shifter linkage will cause problems on my car.
I already have the dual hump cross member so I don't have to worry about that.
Old Aug 7, 2009 | 06:25 PM
66400's Avatar
That shift linkage only applies to 65-70 full size Olds with dual exhaust due to the steering box location. Henry
Old Aug 10, 2009 | 05:39 AM
Thanks for the info Henry.
debfahey
Oct 4, 2014 10:57 AM
ddx77
Apr 29, 2010 12:20 AM
saved2az
Nov 23, 2009 07:26 PM
saved2az
Hurst/Olds
Nov 22, 2009 08:26 PM
