Floor Shift console conversion
Old Aug 13, 2016 | 04:24 PM
RonFX's Avatar
Guys:
I am in the process of installing a floor shift console unit from a 67 Cutlass into my 66 Cutlass Turbo 400 unit. I bought the cable, cable bracket and selector arm for a 67 unit, the problem I am having is the there is approx 3/4" difference in the mounting points between the bracket and arm. There is enough material on the selector arm to mount the pin in a different area and leave the cable bracket in the correct holes on the trans, or would it be better to leave the pin in the selector arm original hole and modify the cable bracket. I'm sure someone has run into this before, any help would be great.
Thanks, Ron 614 309 1513
hvysupreme
Feb 18, 2017 12:40 PM
Alocatelli
Dec 10, 2012 07:49 AM
onofre442
Jun 25, 2012 09:56 AM
Oldsproject
Apr 23, 2010 04:19 PM
rlang
Nov 7, 2009 01:52 PM
