do I need a trans cooler?
1970 cutlass,455,400 B&M trans. engine is mild(basically stock with fresh rebuild,a little cam added etc.) @1400 full size stall.I had a aluminum radiator built for it and the radiator builder said no need for the cooler as the new rad is built with 4 cores cooling and has the big trans cooler in the tank.just wanted some other input. I do drop the hammer now and then(well maybe more than not) and is mainly street driven,I will probably run down the 1/8 a little to see what it runs,but is mainly street in nice weather.any replies greatly appreciated![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
thanks--jack
thanks--jack
From your description, it does not sound neccessary, BUT I agree with the others - it is cheap insurance.
If you live in the south where "nice" weather is still 90*, the cooler will be even more desirable.
x5
You should definitely have a cooler in the radiator. If you are having an aftermarket radiator built you could always spend extra and have an external transmission cooler built. Better to be safe than sorry.
Yes, x100
Remember, if the engine ever get's hot, so does the transmission.
Many newer cars (I know yours is not) have plastic thrust bearings that can melt.
I even put one on my wife's Kia.
Mount the cooler to receive the fluid after the radiator does.
Very inexpensive insurance.
Jim
Jim
cooler all the way i have a funny story about one sorry if it offends some !!! I worked a uHAUL and installed hitches and trans coolers there was this training and we couldnt find anyone but a rather large lady that wanted to use her vehicle to train new employees on.. lets just say the geo metro she drove she barley fit in! and I would say that was a car in need of a trans cooler for sure lol
thanks for all the replies and majority rules!it is getting a external cooler![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
can someone tell me which is in and out (high and low)at the radiator?not saying they haven't been screwed up at the trans also as this was a 350/350 car originally and was converted before I got it with a big car 455/400 swap.I guess the best way to know for sure would be to leave both lines cracked loose and start up and the first to spew fluid would be in?my guess would be the supply (pressure)would be the top and the lower the return but just a guess
The top line runs to the cooler in the radiator using the top hole. The bottom hole in for the cooler in the radiator runs to the top of the external cooler. Than the bottom on the external cooler runs to the bottom on the trans.
Hmm, I guess I am on the other side of the debate.
From what I have read an internal radiator transmission cooler is really all you will ever need in terms of keeping the fluid temp from getting too high, and it also has the added benefit of actually heating cold tranny fluid up to optimal operating temp.
A secondary heat exhchanger bolted infront or behind the main radiator that is dedicated to transmission fluid is much less efficient at raising it to optimal temp and in very cold weather can actually prevent it from reaching optimal temp. I want to say I also read somewhere that it can lessen the overall air flow through the radiator and cause problems, but my own thought would be the reduction is negligable.
My understanding was that secondary heat exchangers originally came to be, as a quick cheap fix for when an in-radiator unit was leaking as they are a PITA to repair.
Admittedly, Racing and "Manu-Matic" applications are probably a whole 'nother story though...
Just my $.02
WOW! What an IDIOT this guy was... Who let him post on here?![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Just my $.02
![Embarrassment](https://classicoldsmobile.com/forums/images/smilies/redface.gif)
Last edited by Coltonis; October 28th, 2009 at 02:03 AM. Reason: Is talking out your @$$ a valid reason?
[quote=Coltonis;118975]Hmm,
That's not smart to use it as a quick fix better off to take the radiator to get it fixed.
I have used second coolers on all rwd cars. My trucks I've used them because I use my trucks as trucks and I tow with them. I use to drag race a lot If I didn't use one the trans wouldn't last. A 50 dollar cooler is cheaper than a 500-750 dollar trans.
I agree that it would not be smart, I wasn't advocating it. The proper fix would be to stop the leak, not to mention flush the water and oil systems that were intermingled.
And yes, I forgot to mention this one, but towing heavy loads would also be a prime use case for a secondary cooler as there would be much more heat produced from all the frictions and the torque converter. (Loosely equivalent to a car purpose-built for racing.)
But for a car built for the street even running races, I would say save your $50 based on the info I have seen an internal radiator unit is all that is needed to keep the fluid temp down. And since there are potentially some downsides with over-doing-it with the secondary heat exchanger, it seems unnecessary to me.
Wow this Idiot is still going... Is there a mute button for stupid people anywhere in the preferences?
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Just my $.02
Just my $.02
Check any car in AZ with 50k+ mileage, that does not have a cooler, for burnt transmission fluid. All will be burnt, unless it was changed.
Radiator only based units are inadequate for ALL cars in this sate, and for most vehicles even back east.
Hell, even the Post Office put them on all of their trucks in Phoenix, saved them tons of money.
Jim in Phx
So I started to wonder and went back and looked at the book I had *ahem* thought I had read this info in. Lets just say I had more things bass-ackwards than I would care to list...
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
The one paragraph I remembered quite vividly as talking about aux. cooler vs no cooler and was in fact debating aux. cooler in-line with rad unit vs aux. cooler stand alone.
Everything I said in previous posts ... disregard.
Auxiliary transmission coolers are the greatest thing since sliced bread, who knew!? (well aside from all you guys, that is.)
HAH! That'll teach you guys to let me give advice around here...
Tony72Cutlass'S'
April 7th, 2013 05:28 PM
bjtstarfire
December 13th, 2008 08:48 PM
