dimensions of slim jim?
Hi, again, needing more info since I'm not at home to measure myself. Maybe someone has a slim jim sitting in the shop they can measure.
What is the total length?
what is the length from bellhousing face to mount bolts?
Do you think the overall body diameter is about the same size/smallerbigger than a 700r4?
I found measurements easy on the 700r4. I'm just trying to prep as much as possible so less surprises when I start on this project.
what are you putting in?
Ok....more update and questions if ANYONE can help.
So I found the adapter kit that Bendtsen's makes which looks more enticing than adapting a bellhousing, but then there's the problem of the trans tunnel. This kit pushes the trans back quite a bit. Hard to tell without trial and error whether you'd have to cut the tunnel either way.
Ok soooo the 200r4 is shorter but the overall body looks to be the same size as a 700r4. I REALLY don't want to cut the floorboard but if it means using the shorter trans, I will. If I have to cut the tunnel no matter what I use, then who knows what the hell I'll do.
If anyone can shed some light on this conversion in a starfire...please help.
thanks
thanks
thanks
thanks
You may want to check with:
Tony
__________________
Ross Racing Engines
Niles,Ohio
330-544-4466 w
330-720-1282 c
thanks but i'll stick with all original on this one. my bel-air will be a total freakshow though. I have got a 700r4 ( i think) up at my stepdad's shop and when I get my slimjim out, I can compare them for you if you like. Let me know if you still need those dimensions on thursday, I've got some help coming over to start tearing into mine.
I'm not a weirdo about keeping stuff all original, in fact I Think most original equipment is junk, plus good luck finding parts when you break down in the middle of nowhere alabama. but this car is number 134 off of the line and according to the last owner who had it "registered" with some organization it is the earliest known to exist, so that will be a selling point, if it is all original...
ok finally got some info
Ok got ahold of a guy through some other forum. He went with dave smith's conversion and didn't have to cut the floor...it was a 700r4. His friend had to pound a couple of spots but got it in. Could probably tweek the trans crossmemeber or something otherwise.
The bolt in kit from Bernsdat..um is that the name....will definitly require cutting the floor. But this leaves you open to other trans's later on and or not having to get a whole new case redone if the case cracks or becomes un rebuildable. Since my car had been carefully rebuilt to factory, I opted for the mod'd case. If I was building a car that was considerably modified, I would go with the bolt on kit.
Hope this info helps.
sweet, i may end up doing that and just leaving the slim jim in the trunk in case the people want to complain about it not being original. Seems like you could fab up a transmission crossmember pretty easily and keep the old transmission, crossmember, and driveshaft to go with the car if the buyer wants it. I'm going to tinker on my slim jim some tomorrow and over the weekend, if I can't get it going easily I may try to get my stepfather to give me one of his 700's. It would definitely be nice to drive the car fast and hard, rather than baby it to protect an obsolete transmission. I'm not wanting to make it unoriginal, but if everything I did was just bolt on then that may be the way to go. I'll post the measurements of the slim jim on here when I get the car up in the air.
bjtstarfire
Drivetrain/Differentials
December 6th, 2006 09:56 AM
