Different in Jetaway
As far as fitting one in place of the other , no . They will interchange . According to the Hollander .
There probably were many small differences in shift points , etc , between various transmissions that were teamed with different engines . .
Also 1965 442 models had a different Jetaway .
Ok , I see what you're looking for .
It's called a connector . It connects to the wiring harness and the valve body inside the trans .
It looks like if both transmissions are V-8 then they will swap .
