Different in Jetaway
Old Aug 11, 2018 | 05:42 AM
64CutlassConvertible's Avatar
Is there any different in 1964 Cutlass Jetaway and 1965 Cutlass Jetaway transmission?
Old Aug 11, 2018 | 06:26 PM
Charlie Jones's Avatar
Phantom Phixer
As far as fitting one in place of the other , no . They will interchange . According to the Hollander .
There probably were many small differences in shift points , etc , between various transmissions that were teamed with different engines . .
Also 1965 442 models had a different Jetaway .
Old Aug 11, 2018 | 06:54 PM
Thanks! Charlie, did they use the same solenoid on the side of the transmission?
Old Aug 12, 2018 | 10:51 AM
Phantom Phixer
By "solenoid " do you mean the modulator ?
If so, the answer is probably not . there were many modulators used in '64 & '65 .
Old Aug 12, 2018 | 11:36 AM
A friend gave me 1964 Oldsmobile Service Manual number 1,2, and 3, today, he bought at an auction. Here the photo I was looking for. Thanks for help Charlie!
Old Aug 12, 2018 | 11:46 AM
Old Aug 12, 2018 | 12:51 PM
Phantom Phixer
Ok , I see what you're looking for .
It's called a connector . It connects to the wiring harness and the valve body inside the trans .
It looks like if both transmissions are V-8 then they will swap .
Dec 25, 2018 01:22 PM
Bfg
Dec 17, 2018 05:20 PM
Christopher Michael Drew
Dec 17, 2018 11:47 AM
Bfg
Nov 14, 2018 06:38 PM
Green-machine
19
Jul 18, 2018 05:00 PM
