Crossmember location with saginaw trans
My brother-in-law is doing a frame off on a 65 Cutlass. The 455 in mounted in the frame with the bellhousing and Saginaw trans. The crossmember is under the trans mount and it does not match any of the 4 bolt holes in the frame. It is behind them toward the rear end. I know now I should have taken a picture.
He and his mechanic believe they will have to drill new holes and shorten the driveshaft.
I was under the impression that the stock auto tranny and a Muncie (or Saginaw) were all short tail trannies and that the middle holes on the frame were where the crossmember was bolted and a shorter driveshaft was not neeeded. Am I wrong?
John
John
They are all the same. In addition to the crossmember orientation, verify that the motor mounts on the 455 are bolted to the rear two of three bolt holes in the side of the block. If the wrong holes were used, the engine and trans will be too far rearward.
GStage1
November 28th, 2023 02:42 PM
epinkston
Paint
March 3rd, 2012 11:32 PM
