Console gearshift detent button
Old June 11th, 2017, 02:34 PM
Cutlass Fan's Avatar
I had to remove the T handle from the lever in order to remove the console in my 65 Cutlass. Unfortunately when it came apart I wasn't able to see how the button connected to the rod that operates the detent and I can't find any explanation or pictures of how to put it back together in the SM. Can anyone provide me with some assembly pictures or instructions.
Cutlass Fan is offline
Old June 11th, 2017, 06:26 PM
The detent rod has a roller at the top. The button has a ramp that simply pushes the roller (and thus the detent rod) down when you press in on the button. Just put the button and spring in the T-handle, bolt the handle in place, and you're done. Unfortunately, the ears on the handle that hold the roller frequently break, rendering this system unworkable.
joe_padavano is offline
Old June 11th, 2017, 06:55 PM
Thx Joe, that helps a lot
Jimmy Jo
June 9th, 2014 05:17 PM
jpaulwhite
April 6th, 2011 02:38 AM
arodenhiser
May 19th, 2010 01:03 PM
84oldsDelta88
January 19th, 2010 11:04 AM
69 Cutty
August 24th, 2006 08:16 PM
Quick Reply: Console gearshift detent button
