Column to floor shift swap
Can someone please tell me in detail how to convert my column shift so I can use a floor shift in my 72 Cutlass.
I know I have to pull the pin and remove the shift lever and grind off the hump, but how do you lock the column so the neutral safety switch still works. What happens to the linkage?
Depending on what shifter you go with will determine how you solve this issue. If you go with a stock shifter and console, all you need to so is swap the linkage arm on the transmission for one designed for a floor shifter. It will have the connections for both the cable and the backdrive linkage. An aftermarket shifter MAY be able to do this as well, but I have never seen one utilized like that. Usually the column gets locked in place and the shifter will come with switches that bolt to it for the backup lights and neutral safety functions.
Either way you will need to swap the linkage on the transmission.
This is the factory piece needed for a factory shifter.
Matt, I think only in 1970 the neutral safety switch was in the console. in 71-72 it stays on the column on both column and console shift. On console shift, the backdrive linkage moves the switch as you move the shifter in the console.
So for the poster's question, you do not have do anything, the linkage connects the switch to the transmission,
Linkage or no linkage (after conversion)
i have a 72 that was converted from column to floor.
but the column linkage is still hooked up.
Can i just disconnect that linkage?
Or do i need to continue to have that connected so it rotates the base of the column?
My linkage is so loose sometimes it doesnt rotate enough, is there a bushings kit for that linkage available to tighten it up (if i haveto keep it)
The linkage on the column will need to be connected the same way as if it's a column shift because the neutral safety switch is located at the base of the column. You will notice the column still rotates when you move the floor shifter. If I understand correctly about loose linkage it could be an adjustment or its wore out. When I installed my floor shift it is very tight and I had to fine tune the adjustments before I could get it to shift in all the gears. I sometimes have to rotate the column by hand when I put it in park to remove the key because it won't rotate all the way.
I woild like to talk on the phone if possible but i dont want to post my number on the forum. I'm not familiar on how this forum stuff works completely.
I hope this helps.
I hope this helps.
I hope this helps.
I hope this helps.
So you still have to rotate the column sometimes even though you adjusted everything and the linkage?
That seems frustrating.
I found it I dont shift to "Park" with a little "authority" it's fine. If I don't I sometimes I will then have to rotate the column to remove the key. One of these days I will get under there and adjust it some more. I really don't drive the car often enough to worry about it.
Supe
Beautiful car!
I also shaved the old column shift, plugged the hole and painted it........looks factory. I had to remove the shift indicator from the dash as well, I didnt want to replace the speedo so i fudged it and now it also looks factory. At least the judges haven't noticed it.
Beautiful car!
Supe
Beautiful car!
Beautiful car!
How did you shave it? And what did you fill it with?
I already fixed my speedo
I removed the attachment for the shifter with a cutting wheel and grinder then used JB Weld. I had to put some type of backer (sorry, I cant recall specifically what I used) so the JB Weld would only be as thick as the existing metal and then finished it off like body work to prep for paint.
71este
June 16th, 2014 09:08 PM
