Clunk from yoke
Old Feb 20, 2023 | 08:12 AM
Aragorn's Avatar
Clunk from yoke
Ok, so I've been hearing a clunk when the car goes into gear, starts from a stop, or I shift into gear. I'm not even really sure where to start to fix this as I'm pretty sure there is way to much play in the yoke *at the transmission. Video is included. Thanks
ETA: Really looking for more Youtube videos or something that has a walkthrough of fixing if possible.
File Type: mov
Old Feb 20, 2023 | 08:46 AM
Be SURE it's not a worn u-joint, which is the most likely cause. If that's the case, it's an easy fix. If the slop is really in the rear axle, it could be worn bearings or worn gears. Either way, that's a rebuild of the rear end.
Old Feb 20, 2023 | 08:58 AM
Aragorn's Avatar
Sorry I wasn't clear enough. The play is coming in where the yoke meets the transmission (why I included the video.) You can hear it about a second and a half after I switch between reverse and drive in the video.
Old Feb 20, 2023 | 09:07 AM
The only way there's "slop" in the trans is if the planetary gear sets are worn. I suspect that is not the cause of the clunk. I couldn't get the video to play without downloading and saving it first, and I was not inclined to do that on my computer.
Old Feb 20, 2023 | 09:12 AM
Aragorn's Avatar
https://drive.google.com/file/d/11md...usp=share_link Testing to see if this works maybe. It works for me at least.
Old Feb 20, 2023 | 09:30 AM
That works. The motion at the front is normal. The clunk is not coming from there. Again, check the rear U-joint and the pinion yoke on the rear axle. Jack the rear off the ground, set the parking brake, and with the trans in neutral, try moving the driveshaft back and forth by hand while looking at the rear u-joint and pinion yoke.
Old Feb 20, 2023 | 09:31 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Definitely a bad UJoint, really bad.
Get under it and grab the shaft and wiggle. I'm surprised it hasn't exploded yet or vibrated you out of the car at highway speeds.
Do both ends at the same time.
Buy Spicer or other USA-made joints. Use blue Loctite on the saddle clamp(cleaned) bolts.
Old Feb 20, 2023 | 09:37 AM
Aragorn's Avatar
Thanks guys I appreciate it. I'll take a look this weekend and start shopping.
X2, yes it clearly looks to be a bad ujoint. It also looks to be the original ujoint as I think I see the plastic **** are still in place.
Old Feb 20, 2023 | 09:40 AM
Aragorn's Avatar
Pretty sure it's original, the car basically sat for 20 years after my great grandmother passed and I don't think my uncle or grandfather did much to it after that. I need to do the front bushings as well it looks like and while tie rod ends passed inspection may look at doing those as well maybe this year.
Allan R
Sep 26, 2017 05:53 AM
t_huth21
Jun 9, 2016 08:48 AM
Aceshigh
Dec 9, 2013 09:56 AM
salayc
Dec 3, 2008 09:48 AM
