Bop trans to a 394?
The Chevy case transmissions are more common than the BOP cases. If you're buying a trans for this swap, it doesn't matter which bellhousing bolt pattern you use. Other than the location of a few bolts, the transmissions are otherwise the same. I assumed the OP was really asking about adapting a 1964-up GM automatic (ie, a TH400).
Here's another supplier. Looks like they might not be doing the conversion now though. It's worth contacting them for some info if your dedicated to swapping to a more modern automatic.
https://www.forwhatyouneed.com/index.htm
Look at my old thread it will give you an idea whats involved.
https://classicoldsmobile.com/forums...lim-jim-17372/
Pat
Pat
Full Throttle
February 25th, 2014 06:39 PM
