Best stoplight trans
Hello i am building a 70 cutlass with a olds 350 that will hopefully have 350-400 hp, and was wonder what opinions you guys had on a bolt in trans(would not be opposed to shift kit) car wont be running freeways, some highway 60mph or so not long distances so rpm isnt that big of a deal just want it to be fast stoplight to stoplight have been thing about 2004r. any suggestions?
Where are you located? I have a TH350 that is rebuilt with updated sprags. It was built to have very firm shifts but not neck braking and a slight stall, 2100 +- RPM. Has around 300 miles on it.
[QUOTE=jensenracing77;723403]Where are you located? I have a TH350 that is rebuilt with updated sprags. It was built to have very firm shifts but not neck braking and a slight stall, 2100 +- RPM. Has around 300 miles on it.[/
balsam lake,wi
balsam lake,wi
I could likely sell mine for $600 shipped to your closest Fastenal store. It was rebuilt by Vedders Transmission in Spencer Indiana. He does all my work and the best transmission guy I ever met.
if you aren't into the diy approach a th350 is also an excellent choice. Just need some deeper rear gears and you are running right with the th2004r until you hit the highway.
mugzilla
March 27th, 2010 07:03 PM
