Auto Floor Shifter
Auto Floor Shifter
For those of you who have converted your automatic trans from a column to a floor shifter, did you have to remove the transmission to attach anything? Some of the pictures show the shifter assemblies (Lokar) attached to the transmission like the manual ones. I am thinking about going to B M shifters Thanks
The Lokar shifters that bolt to the trans case are primarily designed for street rods. The B&M you are considering is a floor mounted cable shifter. There's no need to drop the trans to install the shifter.
