Anyone Used Re-Make Shifter from www.hurstshiftersonline.com
https://www.hurstshiftersonline.com/...categories.asp
Company on line who is re-making Hurst shifters for Olds. I am looking for at a 70 hurst competion plus shifter for a console car. $600. Includes an install kit and shifter, rods, tabs, chrome H lever, ball.
Question: Has anyone every used these folks?
I have talked with one other person off ClassicOlds who has these parts used but they were higher than I wanted to pay. Does anyone else have these parts?
Thank you.
Thank you.
First, that site is not Hurst. It is apparently a reseller. Second, no one is "re-making" anything. PN 3917308 that they show for the Olds applications is available new from Hurst. These are not repros of the original factory shifter, they are the best available fit using currently-offered Competition Plus shifter bodies and sticks. This same PN is the one listed for full size Chevy trucks, by the way.
That same shifter is available everywhere - Summit, Jegs, etc. Apparently Hurst is setting the price, because everyone has exactly the same price as Hurst shows on their web page. I guess I'd shop around for a discount or buy it when Summit/Jeg's/Speedway have discount days.
Personally, I'd buy an original and get it rebuilt.
I went to the Hurst site and used the part number mentioned. 3917308. It says application if the Buick Gran Sport. In looking at the shifter and chrome shift lever, it does not seem to have the bends in it to clear the console. Are you saying that a shifter, chrome lever, install kit--rods, tabs etc are available from Hurst? I could not find any applications at the Hurst site for 70 442.
You might try searching eBay for the correct OEM Hurst shifter, have the handle replated and rebuild the shifter body as needed. I have rebuilt several of them and they are pretty straightforward. The hardest part is keeping the shims in the proper order
I understand. So you think if I call Hurst they can hook me up with a set up that is going to work with my 70 console?
I am not doing a resto or show car. But on the other hand it needs to function property and look stock. I do note on the HurstOnLine parts, that the chrome shift lever has two bolts to hold it to the shifter, while the stock Olds 4 speed of 70 vintage is a push in model with one bolt. Never had my hands on one previously. Maybe more differences.
So if this HurstOnLine is reselling Hurst parts I am not sure the downside? It does not look to me like they are more expensive. His package including Hurst Competition Plus shifter, chrome lever, two handles one a ball and one an aluminum t-handle, shift rods, tabs, bushing, clips etc around $600.
Also, I am not finding an application directly from Hurst that works? Thoughts?
Here's the factory shifter:
While not the exact shifter I used, this gives you an idea of the one I bought as an aftermarket unit. These photos are for a 1969-72 Chevelle with console. This might be your best available option for a new shifter today.
Here is one on ebay you might be interested in.
http://www.ebay.com/itm/Hurst-4-Spd-Competition-Plus-Shifter-Muncie-w-linkage-442-Chevelle-GTO-3915401F-/332227435469?hash=item4d5a4c5bcd:gboAAOSw3v5YoNA E&vxp=mtr
http://www.ebay.com/itm/Hurst-4-Spd-...5YoNAE&vxp=mtr
That shifter is neither the correct factory shifter for a 70-72 console nor the new aftermarket Chevelle shifter with the the "L" shaped offset.
In the early 1970's Hurst sold complete shifters in one box(shifter&install kit), and Hurst shifter #291-7822 was for a 1970-72 Olds A-body non-console...
The great part of this shifter was that it worked with the O.E.M reverse lock-out back-drive linkage...
A little later in the 1970's Hurst started selling shifters in two box's, shifter body and handle in one, and install kit in another. Now you could get install kit #373-8608, and console shifter #391-8792, or non-console shifter #391-6848...
I have some of this stuff in stock...
Hope this helps... Crash ---- crash_enterprises@yahoo.com
Contact Dennis Maroudas dba DME 606-237-6648
He specializes in OEM Hurst shifter rebuilding/handle chrome plating. I had him bend the commonly found 67-69 442 stick to match the contours of the 70-72 console stick. He had it chrome plated then matched it to the correct angled lower mechanism that was rebuilt and replated like new. He does top notch work.
I thought so. I've seen ones on ebay that looked similar. Of course, the correct stick for a 70-72 console is very hard to find and priced accordingly. The last one I saw on ebay was asking something like $295 - for just the stick.
The correct shifter # is 7169, stamped on the bottom of the shifter handle.
The correct Hurst shifter mechanism is stamped 3138.
Be aware that the factory unit uses rubber bushings, while the factory unit uses metal bushings.
cutlassefi
November 28th, 2013 12:08 PM
auto_editor
July 10th, 2011 11:20 AM
68cutlassdriver
Body work
February 17th, 2011 11:06 PM
jeffreyalman
January 15th, 2011 01:24 AM
