Any Recommended Rebuilders in NC/VA/MD? TH400
Old May 3, 2013 | 07:19 PM
Flye's Avatar
no longer need. thanks.
Old May 3, 2013 | 08:37 PM
Erinyes's Avatar
One suggestion: Get Bruce Roe's switch pitch controller, after verifying it works. It probably just isn't getting juice, if it isn't working, but double-check.
Roe makes an electronic controller that measures engine load and has adjustable timers so that the switch pitch works whenever conditions warrant, rather than only at idle or WOT. He's currently integrating an electronic vacuum switch in place of a mechanical switch, which should also lower the price a bit.
bcroe at juno dot com
Old May 4, 2013 | 06:22 AM
Flye's Avatar
Thanks,
jankyrre
Sep 15, 2013 08:35 AM
junior supercar
Jul 2, 2013 04:01 PM
jensenracing77
Jan 13, 2013 02:19 PM
Cameo White
Oct 24, 2010 04:52 AM
import extermination
Aug 1, 2009 10:09 PM
