72 CS Transmission Issue
Old November 1st, 2013, 05:04 PM
MrTorresJr's Avatar
I have driven my 72 CS a few times and never encountered this issue that I did today. I positioned it in 'DRIVE' and upon accelerating it sounded as if the RPMS were increasing yet the speed was not. I flushed the tranny, replaced the gasket & filter about 1 month ago, thoughts? I tried shifting through the gears and still encountered the same issue.
MrTorresJr is offline
Old November 1st, 2013, 06:40 PM
Are you sure the tranny has enough fluid? If it worked fine before the flush chances are you just need to top it up?
Allan R is offline
Old November 1st, 2013, 07:56 PM
Please note, I moved your post to the correct category.
I would check the hose to the modulator and/ or the modulator itself. Item #2 would be to check the detent cable between the gas pedal and the transmission to see if the trans is hung up in passing gear.
oldcutlass is offline
1yesfan
August 4th, 2015 06:40 PM
Dead Reckon
July 14th, 2014 02:35 PM
Outlaw88
November 3rd, 2013 10:41 AM
MrCoolbreeze55
June 19th, 2013 08:34 PM
boylost
Aurora
August 29th, 2006 06:46 AM
Quick Reply: 72 CS Transmission Issue
