700-4r
Old May 27, 2010 | 02:56 PM
80_cutlass's Avatar
700-4r
I am toying with the idea of using a 700-4r that I have in my g-body. The hitch in my get-a-long is that it is a 4x4 version of said transmission. I have done this with 727s (gone back and forth between 4x4 and standard tails) but never with 700-4r. It it from an 89 suburban and has been recently rebuilt, so that is good. In any case, any suggestions?
sb
Old May 27, 2010 | 07:04 PM
sb
Lot's of guys on this site have been bolting in 700-4rs. I don't see why yours would be any different.
Old May 27, 2010 | 09:20 PM
70 cutlass s's Avatar
To put the a 700R4 behind a Olds engine you will need a adapter for it to work. Then you will need to change the output shaft and get a tail shaft for the transmission. Which means taking the transmission all the way apart.
Old May 28, 2010 | 01:45 PM
The GM transmissions use a different output shaft and tailhousing between 2WD and 4WD. The output shaft is the last part out of the case and the first one into the case on reassembly. It's a complete trans rebuild.
jaunty75
Dec 22, 2010 06:04 AM
Charlie_brown
19
Mar 1, 2010 10:18 AM
MN71W30
Jul 18, 2009 07:23 AM
RPD1659
Jul 11, 2008 07:11 AM
Olds64
Jan 29, 2008 06:17 AM
