69 cutlass s with turbo350 tranny
Old Oct 28, 2022 | 11:22 AM
lala5818's Avatar
Does the kickdown cable just go directly from the accelerator pedal to the transmission? My assembly manual keeps showing a downshift switch assembly and my American auto wire kit has a connector for the switch. I'm looking at my pre restoration pictures and can't find a switch? Is there a difference between the turbo 400 and turbo 350?
Old Oct 28, 2022 | 01:01 PM
Yes, the TH400 uses an electric kickdown switch and the TH350 uses a cable.
Old Oct 29, 2022 | 07:17 AM
Both the TH400 and Jetaway (which was used in Cutlii for the first half of the 1969 model year) use an electric kickdown. The harness came with that connector and wiring installed no matter what trans you ordered (even MT cars got the same wire harness).
Old Oct 29, 2022 | 08:55 AM
lala5818's Avatar
Thank you for the responses...
1968Cutlassfallbrook
Jan 26, 2022 07:52 AM
67Rocket
May 27, 2016 12:16 PM
Austin Trevor White
Apr 2, 2013 12:46 PM
AZ455
Nov 27, 2011 08:35 AM
mcutlass1969
Feb 11, 2007 05:33 PM
