67 Cutlass Transmission
Old January 16th, 2015, 01:00 PM
Skeetman's Avatar
I now have the original 2 speed transmission that works ok but sure leaks a lot. Rather than rebuild I could replace with a better option.
Will a BOP 400 fit? The motor is the original 330. I also see the th350 with long and short shafts. What would be the best option?
Skeetman is offline
Old January 16th, 2015, 03:29 PM
The short 350 would bolt right in. If you go with a long 1 or a T400 then there are other mods that need to be done at the same time. If your not replacing with another switch pitch trans a new torque converter will be required also.
oldcutlass is online now
Old January 17th, 2015, 02:34 AM
Rocket Renegade!
I did the THM 350 swap on my '64 Cutlass years ago. Worked beautifully. IIRC the worst problem was adapting the floor shifter so the quadrant made sense.
BangScreech4-4-2 is online now
Old January 17th, 2015, 06:45 AM
I'll add 1 more thing for a T350 swap, you'll need to adapt a kickdown cable.
Old January 18th, 2015, 12:11 PM
Skeetman's Avatar
Thanks for the advise guys. I have swaped a powerglide for a th350 in a chevelle in the past and added a kickdown cable.
seems easy enough so I'll be shopping for a BOP th350 short shaft.
Skeetman is offline
marcar1993
Drivetrain/Differentials
25
December 10th, 2008 06:23 AM
garlandl
July 3rd, 2008 05:50 PM
djodja29
May 2nd, 2007 06:32 PM
WasteOfMind00
February 24th, 2007 10:14 PM
Cuttyon22s
July 10th, 2006 11:24 PM
Quick Reply: 67 Cutlass Transmission
