67 Cutlass Transmission
Old Jan 16, 2015 | 01:00 PM
Skeetman's Avatar
I now have the original 2 speed transmission that works ok but sure leaks a lot. Rather than rebuild I could replace with a better option.
Will a BOP 400 fit? The motor is the original 330. I also see the th350 with long and short shafts. What would be the best option?
Old Jan 16, 2015 | 03:29 PM
The short 350 would bolt right in. If you go with a long 1 or a T400 then there are other mods that need to be done at the same time. If your not replacing with another switch pitch trans a new torque converter will be required also.
Old Jan 17, 2015 | 02:34 AM
I did the THM 350 swap on my '64 Cutlass years ago. Worked beautifully. IIRC the worst problem was adapting the floor shifter so the quadrant made sense.
Old Jan 17, 2015 | 06:45 AM
I'll add 1 more thing for a T350 swap, you'll need to adapt a kickdown cable.
Old Jan 18, 2015 | 12:11 PM
Skeetman's Avatar
Thanks for the advise guys. I have swaped a powerglide for a th350 in a chevelle in the past and added a kickdown cable.
seems easy enough so I'll be shopping for a BOP th350 short shaft.
marcar1993
Drivetrain/Differentials
25
Dec 10, 2008 06:23 AM
garlandl
Jul 3, 2008 05:50 PM
djodja29
May 2, 2007 06:32 PM
WasteOfMind00
Feb 24, 2007 10:14 PM
Cuttyon22s
Jul 10, 2006 11:24 PM
