66 Delta 88 - What tranny was stock?
What transmission came on the 66 Delta 88 with the 425 High Compression engine? And is this transmission sufficent for a car that will only be street driven with an occasional traffic light race?
Thanks! I have two transmissions. Both automatics, one original to the 66 Delta 88, one from a donor car which had apparently had a heart transplant at some point. As soon as I find out what they are and which one I am going to use, I'd be glad to give the other one away to anyone willing to pick it up or pay to ship it. I'm in Atlanta.
Lots of pics. I had quite a few posted in the 'previous' gallery until the 'Big Crash' of 2007 (the gallery, not the car, LOL).
Here's an album link:
http://www.madmax.smugmug.com/Cars
Enjoy, only 35 degrees but sunny.
I certainly will. Right now it's completely gutted out. We just got the engine & tranny back in, and they look GOOD. After that It's going to be in my shop for a while to finish the prep & paint work. I won't be one of these guys that asks everyone for help & then doesn't even give them a chance to see what they were helping with. Pics will be coming soon.
From the manual
Although we've established that the transmission in question is an automatic, here's a small clipping from the 1966 Service Manual that shows what manual transmission goes where:
So although you could get a "Heavy Duty" or a "4-speed", you couldn't get both.
Later, it states that the close ratio version was not available on the big cars.
Do you plan to punch through the hood?
My 67 has a Performer carb and manifold. I have to use the freeflow (top filter w/screen) air filter due to the low hood clearance. I've even toy'd with installing a supercharger, if I could find one. I have a line locally on a good hood that I would modify for this installation.
Looks good!
Looks good!
Look at the electrical connector on the trans. I single terminal on the connector indicates that it is a standard TH400. Two terminals in a "T" configuration indicates either 1) it is the original switch pitch or 2) it is a replacement from the 1970s with the pressure sensor for the transmission controlled spark system.
odddoylerules
24
January 22nd, 2014 06:35 AM
<jdhideaway@aol.com>
Brakes/Hydraulic Systems
March 31st, 2005 08:15 PM
