Is a 61-64 slim Jim the same?
Old August 27th, 2015, 02:50 PM
eddieunderground's Avatar
I have a 62 dynamic. Would a 64 dynamic transmission switch out the same?
eddieunderground is offline
Old August 28th, 2015, 04:56 AM
coldwar's Avatar
I think so. Pontiac also.
coldwar is offline
Old August 28th, 2015, 05:22 AM
GEARMAN69's Avatar
The Pontiac slim jims are in Catalinas but not the bonnevilles they had super hydramatics
GEARMAN69 is offline
Old August 28th, 2015, 09:03 AM
Oldsdruid
rocketraider's Avatar
Long wheelbase Pontiacs (Bonneville/Star Chief) used the four-speed Super HMT (Jetaway in Olds-speak). The Catalina/GP used Slim Jim.
Why in the pluperfect hell Olds went to Slim Jims across the board 61-64, I can't figure.
But yes, a 64 Olds Slim Jim will fit and work in your 62. The big differences are valve bodies. Keep in mind that with SJ, "work" is often defined loosely...
rocketraider is online now
Old August 28th, 2015, 11:15 AM
Oldskeeper's Avatar
You will have to change the tail shaft housing, 64 speedometer works off the front tire through the spindle and the 62 has the speedo in the rear housing of the transmission.
Oldskeeper is offline
Old August 29th, 2015, 06:53 PM
@oldskeeper Does that require a lot of work. And what exactly has to be done?
Old August 30th, 2015, 03:44 AM
Phantom Phixer
Charlie Jones's Avatar
Pontiac slim jims wont fit in an Olds.
Front of case is different.
Charlie Jones is online now
Old August 31st, 2015, 07:55 AM
Oldsdruid
Didn't Pontiac use an adapter bellhousing same as Olds? Olds piece is not as thick as Pontiac, and the 61-64 Pontiac piece uses the 65-later Turbo HydraMatic bolt pattern- which makes a THM conversion simple for Slim Jim equipped Pontiacs.
Steve, had forgot the 62 drove the speedometer off the trans. I'm too used to 63-later...
Old August 31st, 2015, 05:07 PM
Phantom Phixer
The front case cover is different between Pontiac and Olds . This is the adapter bellhousing you speak of. Other parts of the trans may or may not be the same.
The biggest problem with the slim-jim to THM conversion on a Pontiac is that 63 and earlier engine had a bellhousing mounted starter so they still require an adaper plate to mount the starter. 64's had a block that a starter could be mounted to.
GeneS12320
April 28th, 2008 06:39 AM
GeneS12320
September 28th, 2007 02:31 PM
RatRod
March 22nd, 2007 08:17 PM
bjtstarfire
Drivetrain/Differentials
December 6th, 2006 09:56 AM
Quick Reply: Is a 61-64 slim Jim the same?
