41 olds transmission
Old Sep 21, 2009 | 11:19 AM
Robert Kiedrowski's Avatar
rkiddo41olds
Have a question on how the hydramatic shifts. This unit was overhauled 9000 miles ago and shifts as follows- from first to second shifts smooth, from second to third it shifts with a noticable sift and the last is smooth. My question is, is this a normal shift mode to feel the second shift or do I have a problem? An answer would be appreciated.
Old Sep 21, 2009 | 11:28 AM
delmontcrusier's Avatar
67 heavy metal
welcome to classic olds I am shure someone will have the answer soon.
Old Sep 21, 2009 | 01:01 PM
rocketraider's Avatar
Oldsdruid
Most of those old HydraMatics had very pronounced shifts thruout their ranges. That's the claimed reason Buick would not use it, because it was "jerky", though I've always believed it was because the HydraMatic was not designed and built in Flint. Hey, it was good enough for Cadillac...
I have ridden in both 41 and 42 HydraMatic-equipped Oldsmobiles and can vouch for being able to feel the shifts.
Now if it's shifting hard enough to jerk the whole car, you may have a problem.
Old Sep 21, 2009 | 01:58 PM
Oldsguy's Avatar
Past Administrator
welcome to CO.
Old Sep 21, 2009 | 03:08 PM
citcapp's Avatar
Had one in my 57 as you stated the shift from 1st to 2nd was hardly soft and the shift from 2 to third was hard. Every one I have talked to says the same thing about these trannys. I just learned to live with it never had a problem.
Old Sep 21, 2009 | 03:43 PM
Is there a TV adjustment on cars that early? I am not sure if there is or not. If so, if this is out of adjustment it could cause erratic shifting. I've also heard that the early transmissions have odd shifting habits.
Old Sep 21, 2009 | 04:18 PM
rkiddo41olds
Pookster6
Jan 14, 2016 02:29 AM
Pookster6
Oct 31, 2011 11:52 AM
mikey0560
Oct 14, 2007 09:08 AM
lou_harris
Jan 4, 2007 02:42 PM
155thINF
Sep 20, 2006 10:15 PM
