400 turbo tranny ?????
Old Jul 2, 2009 | 09:18 PM
0590trab's Avatar
Hi, guys I just purchased a 400 turbo tranny, it looks like it is full of oil or some other oil looking type of fluid in it, there is no red fluid in it,has anybody ever experienced this before, is there a clear transmission fluid on the market,thanks in advance for any and all help...........trab
Old Jul 3, 2009 | 04:15 AM
f-85 rallye's Avatar
Hello! Is this a trans. you were going to rebuild anyway?
I know I've never heard of clear tranny fluid. Should be red. If it's that dark, it's probably got a nice "burnt" smell to it. If that's the case-look into going through it to rule out any damaged components!
Good luck!
Old Jul 3, 2009 | 05:34 AM
jaysun's Avatar
ate glue as a child
Might be tractor hydraulic fluid. It's clear in color. http://www.yellowbullet.com/forum/showthread.php?t=1436
Old Jul 3, 2009 | 05:59 AM
IMHO most transmission fluids have a "sweet" smell. If it is dark in color it could be old transmission fluid with burnt clutche material in it. If it is clear or pinkish in color it could be that the transmission sat for along time with little or no fluid in it and condensation built up in the pan. Drop the transmission pan and inspect the valve body. You might be able to change the filter, add fluid and drive it.
Old Jul 3, 2009 | 07:48 AM
citcapp's Avatar
I moved this to the transmission forum to get you better coverage
Old Jul 3, 2009 | 08:35 AM
0590trab's Avatar
Thanks alot guys, I found out from the guy i purchased it from it's John Deere hyguard transmission fluid,........New ??? can I get rid of it and switch back to regular tranny fluid ?
Thanks in Advance..........trab
Old Jul 3, 2009 | 08:38 AM
0590trab's Avatar
continuation ???
If so whats all involved just emptying the tranny and converter and refilling with regular tranny fluid....
Thanks in Advance....trab
Old Jul 3, 2009 | 08:39 AM
0590trab's Avatar
how do i change back to regular fluid???????
Old Jul 3, 2009 | 08:53 AM
72 cutlass455's Avatar
Call john Deere and find out if it is compatible with the red tranny fluid. I would guess it is heavy duty stuff and may not break down at high temps. But the folks at Deere should be able to tell you if a bit of residue fluid mix with the red stuff can cause harm.
Old Jul 21, 2009 | 09:46 AM
hotrodpc's Avatar
There you go, I agree with 72. I would call JD and find out if you can mix if with Dextron. Then get all of it out you can, then go ahead and fill with the Dextron if it will mix. Sounds like it may be good fluid. How much is it, what are its properties and what are the benefits and what could be harmed. You might want just to leave it in there and buy some to have around to add later. Although, it would sure be hard for me to get used to the clear trans fluid. So its been awhile since you responded. Just curious to what you decided to do with it or found out. Let us know. Thanks
matviar
Feb 26, 2012 11:05 AM
80_cutlass
Mar 17, 2011 06:03 PM
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
