4 speed hump
4 speed hump
does anyone have a picture of what the bottom of the hump should look like in a 70 442 i want to get the size of the hole right so it looks factory (although no one will ever see it).
any tips would be great
thanks
thanks
I'll try to post pics I took from an original '70 4 spd car showing the factory cutout in the floor.
Warning....it isn't pretty...they used a torch and the hole is fairly ragged....you said you wanted "factory" so that's what you'll get in these pics.
Stay tuned.
Stay tuned.
this is the hole that was in the floor when i got it. i thought from looking at it someone had hacked it in but now im not sure. is this what a hole from the factory would look like? is it possible that i have a 4 speed car?when i got it it had a th350 in it from who knows what and a column shift and i know the steering wheel wasnt original
thats how it looked when i got the car. my guess is they drilled the spot welds and removed the hump. also i got a hump from another car to add on and it lines up with that hole and the holes that could be from the spot welds line up as well.
marxjunk
February 20th, 2015 07:25 AM
